Engine that operates on waste heat or low quality fuels
Is anyone familiar with the STM Power technology? This technology appears to be capable of operating on essentially any heat source (i.e., waste heat from incinerators, thermal oxidizers, pyrolysis, or low Btu fuels like landfill/coal bed methane). The company's web site is www.stmpower.com and it appears to be a technology that could be applied to multiple applications.
RE: Engine that operates on waste heat or low quality fuels
Then we can really analyse the advantages against the cost
It was developed many years ago and was known as the STIRLING EXTERNAL COMBUSTION ENGINE look it up in your reference books or library, it makes fascinating reading. Certainly seems like a fantastic idea.
For a nice little description of the Stirling Engine (though aimed more at cars), principal and its applications, try: www.howstuffworks.com/stirling-engine.htm
The howstuffworks site is always a nice and easy place to find out about things. Also, http://www.sesusa.org/
is a good starting point. Lastly, this company also offers power generation at a small 200kw range from a number of waste heat sources http://www.stirlingadvantage.com/
Andrew
(ps; Elvey, i am interested in what you are doing with this H temp incinerator, i am also involved in pilot applications (extensions of waste to energy concept) for small scale waste (incineration) thermal treatment plants).
Also check out http://www.stirlingenergy.com/default.asp who by using solar power (reflect light onto the engine) makes THE most efficent use of the suns power, as stated in a study done by the US goverment
Paul Elvey
What are we going to do, run jack shafts, pulleys, and belts down through the plants again, to provide the necessary mechanical power to equipment? Steam and turbines or Electricity and motors are much more efficient and cheaper.
saxon ;)
