Mass flow relative to shell noise
I have two sets of mass flow rate data vs. crank angle. one mass flow rate has higher amplitude than the second set of mass flow rate data, but the average of the mass flow rate for both are the same. Would it be safe to say that the mass flow rate with the higher amplitude has more effect on the shell noise than the one with the lower amplitude, even though, their mean mass flow rate is the same (approximate delta of the amplitude is .06kg/s)?
RE: Mass flow relative to shell noise
Surya Prakash
Project Manager
surya@tecumsehindia.com
Thanks for interest.
Cheers
Greg Locock
Surya Prakash
Project Manager
Thanks again
