Mass flow relative to shell noise
I have a dilma, Can mass flow be a determine factor for shell noise?  I have two cases and they both have the same average mass flow rate, but their amplitude is different (mass flow vs. crank angle).  One has a higher amplitude than the other.  The mass flow rate data was picked from the rpm that has the shell noise issue.
