Lamps for Night Vision Goggles (NVG)
I'll try this forum first ....
I'm looking for suppliers of T1 3/4 filament lamps fitted with NVG filters, or who can supply separate filters for this size lamp, so that I can make existing equipment NVG compatible.
RE: Lamps for Night Vision Goggles (NVG)
The other choice might be:
http://www.bemeyers.com
They're mostly NVG compatible laser based sources, tho...
TTFN
Pls check this site may be they solve your problem.
KEREM
If you do a search fo "nvg lamp filter"...
http://www.edmo.com/s4/s4-11c.asp
http://www.catalognavigator.com/oxley/cfm/index.cfm?pag...
http://www.hoffmanengineering.com/HoffmanComponents.htm
TTFN
