density of gas mixtures
Hi
I need to calculate the density of a gas mixture
(60% oxygen/40% nitrogen) 20 deg C, 1 ata.
Is it as simple as using the densities of the individual gases and the proportions or are there other effects to take into account.
thanks
Jamie
RE: density of gas mixtures
Provided there is no chemical interaction between the two gases to form a third substance, density of resulting mixture is in proportion to the concentration of each gas and its individual density.
You may have to account for RH (water vapor) because it will make mixture lighter. If it is a dry gas then disregard.
Remember that nitrogen and oxygen combine into N2 and O2, so their respective molecular weights are double.
Density = P * MW / ( Z * R * T) for a gas mixture.
Z  is the compressibility factor for the mixture.  You can take as 1.0 for your mixture and P and T.
MW is the molecular weight of the mixture.  I'll assume the 60/40 split is on a vol or mol basis so the density of the mixture is 0.6 * 32 + .4 * 28 (these are approximate MW for O2 and N2, you can use more precise ones if you need.
Density is in lb/ft3
R is the gas constant, 10.73 psia*ft3/lbmole deg R
T is the temperature in deg R
P is the pressure in psia.
