material properties ASTM A401
HI,
I am searching for material properties for ASTM A401
especially modulus of torsion and ultimate tensile strength.
I have looked up matweb.com but have not found it.
Thank you.
Thank you.
RE: material properties ASTM A401
Field of use of the selected material
Suitability for fatigue load Very good
Relative strength High
Corrosion resistance Poor
Max. operational temperature - 475 [° F]
Delivered wire diameters / 0.031 - 0.5 [in]
Mechanical and physical properties of the material
Modulus of elasticity in shear – 11200 [ksi]
Modulus of elasticity in tension – 28500 [ksi]
Density - 490 [lb/ft3]
Strength characteristics of the material
Ultimate tensile strength / Su - 260 [ksi]
Permissible torsional stress tA / 166.4 [ksi]
Endurance limit in shear te / 96.2 [ksi]
Endurance limit by finite life tf / 96.2 [ksi]
Mirekp
Mechanical and engineering calculations
http://www.mitcalc.com
For ultimate tensile strength, the minimum and maximum values required by ASTM A 401 vary depending on the wire diameter. 260 ksi ( 179 MPa) is the minimum tensile strength required for wire sizes between 0.177-0.192 inches. If you post again with the wire diameter in question, I can give you the requirements for minimum and maximum tensile strength.
In my case it is a torsion bar (.148" x .148" ).
