Measuring distance on a existing DWG
I have a autocad drawing and want to measure distance between two points on this drawing:A and B.
I don't want length of line AB, But I want overall length of horizontal and vertical lines which connect A to B.
What can I do?
Please reply in step by step form because I am novice in Autocad.
Thanks for your answer.
What can I do?
RE: Measuring distance on a existing DWG
Type "DIST", then "ENDP", pick one dne, then "ENDP" and pick the other end.
If that is too much, "trace" the distance with the PLINE command. Then, LIST the Pline. That will give you total distance.
MFPD: yes I want only total length.
How can I choose point "A" exactly on a line?
Thanks again.
To get a specific point on the line, AutoCAD can "Snap" to certain parts: "ENDP" (endpoint" or "MID" (midpoint). Type either as I have shown above in the middle of your DIST command..
4m
A---------------+
| 3m
B-------+
2m
Net length of lines 4-2 = 2m horizontal and -3m vertical would be given by the DIST command and snapping at A then B. To get total length 4+3+2 = 9m, trace a PLINE then use LIST to get total length.
distance and the vertical distance
you could list the coordinates
and subtract their coordinates.
If you want to construct same,
you could draw a vertical line from point
a to (perpendicular) to point b
and then a horizontal line from
point a to (penpendicular) to point b.
Is this what you are after,
only the vertical and horizontal
distances? You could simply dimension
them using vertical and horizontal
measurements.
