Creating a turbocharger
hi guys,
i just started using solidworks, and am very new at this. I have creating a few parts, but im stuck on something new now. I want to be able to create a blower style housing. ones you see on turbocharges and superchargers. I know i will have to use the loft feature, and different planes, but my big question is how would i be able to create the rotation from big to small and create a small circle.
RE: Creating a turbocharger
CorBlimeyLimey, Barrie, Ontario.
FAQ559-863
The thing is, that it depends a little upon what type of information you havfe to start with... if you have all of the sections of the thing, you might want to try using a loft, if you have profile, and path information, then you might want to look up a sweep on the help menu...
regardless of which one you choose, you should also investigate how to create and use "guide curves"
Hope that helps a little..
Jon
jgbena@yahoo.com
Jon
jgbena@yahoo.com
