Crane Box Girders required
I am looking for a shipyard or large engineering site that has closed with 40 Metre or larger box beams on the cranes.  Any thing over 20 Tonne SWL will be considered. I  will use beams for another project and can inspect and recalculate stress etc required.  Ideal would be a fairly light duty 40 Tonne crane at 40 Metres span.  Has anyone any ideas
RE: Crane Box Girders required
Call up National Eastern corporation, a heavy structural steel fabricator in Plainville CT..  This company or its parent owner White Oak Corp of that same town may have steel of the size that you want.
Thank you chicopee.  I didnt make it clear exactly what I require.  I am looking for fabricated box girders second hand or pre owned as you say.  Thanks.
National Eastern corp may have box girders from altered overhead bridge cranes and mobile hydraulic cranes. Check them out.
A 40 Ton 40 metre span girder crane is not usually found laying around so if you do not find a good used one maybe I can help you get a well calculated and soundly constructed one for a reasonable price at this e-mail sacem1@terra.com.pe
SACEM1
