Creating screws in SolidWorks
Does anyone know how to create screws in solidworks? I mean creating a screw 3-D model which actually screw threads be seen on the stem of the screw.
RE: Creating screws in SolidWorks
If you do a search in this Forum, there are several threads on this subject. But, the best way is to draw the thds in the sketch and revolve it. If you actual thds, you would have to do create a helix...this is more complicated and uses alot more recources of your pc.
Thanks ctopher. There is one I read and it says it may due to my graphic card. I do not get that! Any help?
Check out
http://www.scottjbaugh.com/Design_Portfolio/SW%20Models...
Toward the bottom there is a screw model I made. See if that helps you out.
Making real threads will cause you to take a performance hit . That model above shows some different ways to make a screw thread without taking a Performance hit. Using a revoloved boss and linear pattern is the best way besides just not making true threaded screws, to not take the hit.
Scott Baugh, CSWP
http://www.3dvisiontech.com
FAQ731-376
Thank you all and special thanks for Scott for his SWX file and the idea how to generate the threads.
Appart from special circumstances, we don't even bother to create internal threads and we only do revolves for externals.  This has a hidden advantage.  Unless you model your threads - even revolved ones - very carefully and mate them very carefully (screw that! Heh, heh, heh,...)  there will always be SW drawing file graphics.  Illogical edges disappear sometimes.  And it make some interference checking tasks a real inconvenient pain.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
Also, Scott is hosting a PowerPoint slideshow I made covering this aspect of hardware models.
http://www.scottjbaugh.com/Design_Portfolio/Hardware%20...
Don't mind the personal plug.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Check out www.CADalog.com , it has an inexpensive program called SolidMech (formerly from EMT Software) which creates screws & many other standard parts with ease. It has settings for no thread, simple thread (annular grooves) or full profile threads & all at the click of a button. It is very similar to SW Toolbox but I prefer SolidMech to Toolbox & used it extensively, at first, to create my own library of standard parts.
CorBlimeyLimey, Barrie, Ontario.
Don't Take It Personal, Have Fun While You Learn
FAQ559-863
I created the threads but I needed to know how to create a thread run-out. Scott Baugh was terrific in helping me in this area. Check out the post in this forum dated 7-23-03. I think this will help you out. Good luck!!!
