Arc Detector Sources
I need to use some Microwave arc detectors but only have located  sources that include the wave guide or ell assembly mounted to it.  All I want is the detector and associated control so that I can mount it on the cavity as required.  Can someone advise a vendor or two that deals in un-assembled or seperate units.  Sure would appreciate it.  I want to thank you all for your support given.
Leo
