Key command for viewing shaded planes
I'd like a keyboard command for toggling between shaded and unshaded planes. Under customize->Keyboard I scrolled down the view list and shaded mode is there and planes are there but not shaded planes. Does anyone know where it is located or has anyone created some other kind of shortcut for this?
Thanks.
Thanks.
RE: Key command for viewing shaded planes
I don't know how that could be done, but I don't rule anything out with the use of API.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
Any chance you could you post the macro to do this?
Just for the hell of it, I tried to make a simple macro, by recording keystrokes, to "Tools\Options\System Options\Display\Selection" and either check or uncheck "Display Shaded Planes" but it does not work.
My knowledge of Macros/API/VB is somewhere between extremely limited & non-existent.
BTW: Are you from the "Civilised South" or the ...ahem... "Neanderthal North"?
CorBlimeyLimey, Barrie, Ontario.
FAQ559-863
