Protect a Excel-file with a password
Hi folks,
Is there a way to protect a Excel-file with a password. I want to send (email)een Excel-file to someone else an they can only open it with a password. Is this possible?
Rudi
Rudi
RE: Protect a Excel-file with a password
Too late, I found by myself.
Thanks anyway Rudi
I use protection under the tools menu to protect the contents of some cells and leave others open (protect sheet and protect workbook). However, while hiding formulae and write protecting selected cells, the file can still be opened and viewed by anyone even though they can only change or enter data in the selected unprotected cells.
So to close out this thread, it would be nice to know the steps to prevent the workbook being opened in the first place without a password.
File|Save As|Options|General Options|Password To Open
Brian
Nothing you put in an Excel spreadsheet is completely safe from someone who really wants to get at it.
Brad
You're absolutely right, I've used those same utilities to crack a forgotten cell protection password (which are essentially equivalent to 4 digits, no matter how many digits you use),but I believe a long file open password would still be the safest bet, as the the time to crack can still be years if chosen randomly enough - please correct me if I'm under a misapprehension
Ian
Cheers,
Joerd
Thanks to all it's was very interesting. Since you were talking about cracking tools, were can I find those utilities.
Not to worry I just want the try them out it could be come in handy in the near future.
Rudi
Go to:
http://www.straxx.com/excel/password.html
This is an excellent Excel Password remover. I have used for maybe 3 years and have never had any problems with it - except maybe the popup reminder to upgrade. It's shareware, so you can use it for trial free and pay later if you like it and want to subscribe.
I protect all my engineering worksheets because I can't trust myself (& others) to not make a typo or mechanical mistake in using them - especially large, detailed datasheets. I believe any Excel password can be broken - as this program proves; but the important thing is to get protection from your everyday, clumsy mistakes - and this system seems to work very well for me and gives me peace of mind.
Art Montemayor
Spring, TX
Whilst I try to keep the password to myself, I am not going to lose any sleep if it "escapes". I know that some purists out there will be horrified at this approach, but is has worked for me for quite a few years now.
HTH
I see you have done your spreadsheet protection in the proper, engineering manner - you've automated the application. I envy your ingenuity and resourcefulness and I would ask you to share your VBA code (macro?) so I can start applying it myself. That is definitely the most efficient way to get what I need. My email is artmontemayor37@hotsheet.com. Can you send me a copy? Thanks.
Art Montemayor
Spring, TX
Note that you will have to edit in your chosen password in two places. You will also have to create the necessary shortcuts (if you want them). Finally, if you did it all in an otherwise empty spreadsheet, you can convert it all to an add-in, which will make life a bit easier when you actually come to use the macros.
------ Macros begin ------
Option Explicit
Option Base 1
Sub Protect_All()
' Macro to apply a hardwired password to all sheets in a workbook and to the workbook itself.
Dim WorkSht As Worksheet, NumbSheets As Integer
Dim PassWd, Ans, ShtName As String, StartShtName As String
Const Descr As String = "Macro to protect all worksheets"
' Warn user what is about to happen.
Ans = MsgBox("You are about to protect all sheets in this workbook." & _
Chr(13) & Chr(13) & "Do you wish to continue?", _
vbYesNoCancel + vbDefaultButton1, Descr)
If Ans = vbCancel Or Ans = vbNo Then
MsgBox "Operation cancelled at your request.", vbOKOnly, Descr
Exit Sub
End If
' Set the "hard-wired" password.
PassWd = "PutYourPasswordHere"
' Record the presently-active sheet, so we can return to it when finished.
StartShtName = ActiveSheet.Name
' Loop through all the worksheets.
NumbSheets = 0
For Each WorkSht In Worksheets
WorkSht.Activate
On Error GoTo P_Failure
ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True, Password:=PassWd
ActiveSheet.EnableSelection = xlNoRestrictions
On Error GoTo 0
NumbSheets = NumbSheets + 1
Next WorkSht
' Now protect the workbook.
ShtName = "Workbook's structure"
ActiveWorkbook.Protect Structure:=True, Windows:=False, Password:=PassWd
On Error GoTo 0
' Return whence we starteth-ed, then it's all over.
Worksheets(StartShtName).Activate
MsgBox "All done OK (" & NumbSheets & " sheets)." & Chr(13) & Chr(13) & _
"Password used was """ & PassWd & """." & Chr(13) & Chr(13) & _
"Take care not to forget it.", vbOKOnly, Descr
Exit Sub
' Error handling area.
P_Failure:
MsgBox "Protection attempt failed for """ & ShtName & """ so exercise was aborted." & _
Err & ": " & Error(Err), _
vbOKOnly, Descr
End Sub
Sub Unprotect_All()
' Macro to unprotect all sheets in a workbook, and the workbook itself.
' It assumes that all these protections have been set with the same password.
Dim WorkSht As Worksheet, NumbSheets As Integer, Ans
Dim PassWd, ShtName As String, StartShtName As String
Const Descr As String = "Macro to unprotect all worksheets"
Ans = MsgBox("You are about to unprotect all sheets in this workbook." & _
Exit Sub
End If
NumbSheets = 0
WorkSht.Activate
On Error GoTo U_Failure
ActiveSheet.Unprotect Password:=PassWd
On Error GoTo 0
Next WorkSht
' Now unprotect the workbook.
ActiveWorkbook.Unprotect Password:=PassWd
On Error GoTo 0
MsgBox "All done OK (" & NumbSheets & " sheets).", vbOKOnly, Descr
Exit Sub
U_Failure:
MsgBox "Unprotection attempt failed for """ & ShtName & """ so exercise was aborted." & _
vbOKOnly, Descr
End Sub
------ Macros end ------
Happy passwording.
Cheers,
Joerd
