Cant attach a Blocks to any entities like Planes,face
HI
I cant attach a block in drawing to any entities in drawing.my problem is if any changes in the assembly or part the changes made should propgate & update the block in my drawing .Is there any solution for this?
Senthil Kumar.E (B.E Mechanical)
senthile@geometricsoftware.com
RE: Cant attach a Blocks to any entities like Planes,face
I just tested this and as far as I can tell you can't attach blocks to anything because... it's a block not geometry. You can place it in a drawing, you just can't place it with a relationship to other geometry.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
What is it that you have a block of, and why does it need to update with the geometry?
Is it a scenario like having a special symbol say for instance a surface finish symbol that needs to stay pointing to a certain model edge??
let me know and lets see if we can find a workaround for it.
Jon
jgbena@yahoo.com
CorBlimeyLimey, Barrie, Ontario.
FAQ559-863
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
If the item you are attempting to convert from drawing view geometry to a block is fairly simple, you can try the following trick.
Insert the desired view off the side of the drawing sheet border where it will not normally be seen. Ctrl-click the model edges you want in the block, and use the convert entities command to get them as collection of lines and arcs in the drawing sheet sketch. Move the original view out of the way and window select the new sketch lines to make a block as you normally would.
Then you can insert the block in the drawing sheet(s) as many times as you like.
When the model geometry changes, a full rebuild on the drawing should force all of the block instances to also update. (hint: this may not work if the geometry change is significant enough to remove arcs, or add lines to the profile, this is mostly for changes of size)
If the model geometry change does invalidate parts of the sketch, at least portions of the block should go dangling color. (sorry, haven't tested that case yet) At worst, that would be your signal to explode the block and remake it.
If you're curious, such a trick is sometimes used to create a mask layout drawing, where the instancing nature of blocks is used to create the patterns. That significantly reduces the size of the DXF file exported for Gerber plotting.
DesignSmith
www.DesignSmith-Services.com
