Percent Percent value.......
Sorry if this has been covered before but I am after the percent percent value for mm2. I want the 2 to be smaller and on the top right of the last m.
Cheers
Danjo
Cheers
Danjo
RE: Percent Percent value.......
which textfont? Mostly You can use "altgr"+2, then You get mm²...
Lothar
DPA
1. You can write this only with True Type fonts (Arial, Times etc) not with Romans and others.
2. To do this you have to:
- launch the command Multiline Text (_mtext in Autocad 2000)
- change the font to Arial or other TT font.
- start writing in the windowL: m m then press the Alt key and with that key pressed, press one after each other the keys 0178.
- Release all keys and you will obtain the mm2 correct.
Doru
doru7171@hotpop.com
I have learned, that every country have different keyboards, so DORUs reply is perfect...
I'm confused now!! Does DORU's procedure work in 2000LT??
I can't get it to work, i followed the steps exactly (would be really useful for cable sizes etc).
I followed the below procedure exactly, but no success. When i tried to initially select Arial as the font, it kept reverting to 'TXT' font instead. Only after having written the text could i change it to Arial?? (Don't know if this is relevant)
"launch the command Multiline Text (_mtext in Autocad 2000)
- Release all keys and you will obtain the mm2 correct."
It works also by writing first with TXT font and then changing it. Try this:
- launch MTEXT
- write the text "XX" using the TXT font (or any other font Autocad likes).
- select the text, change its font to Arial, Times etc.
- put the cursor between the X's
- write insite m m Alt+0178 (after this you will probably obtain the correct symbol between the two X's)
- delete the first and the second X
Or you can just go to
http://dorudoru.topcities.com/mm2.zip
and download the block containing the mm2 text
Doru
Do you need to register with the Topcities site to download the block?
No, you don't need to log.... just click my link and launch "Save target as..."
did You solve the problem?
Text, Arial-> type "mm%%174" -> You will get mm²
Lothar
Superscript
1: Put the "^" symbol AFTER the word or number you want superscripted
2: Right-click the text and "^" symbol
3: Choose "stack"
Superscript Examples
"mm2^" turns into mm2
"Mr. Flores^" turns into Mr.Flores
Subscript
1. Put the "^" symbol BEFORE the word or number you want subscripted
2. Right-click the "^" symbol and text
3. Choose "stack"
Subscript Examples
"mm^2" turns into mm2
"Mr. ^Flores" turns into Mr.Flores
You have to do this in mtext; I use Arial, but it works with other true-type fonts.
Hope this helps,
Flores
laters
Danjo
Karel
first I'm sorry. The right code is "mm%%178".
I think it's not a version-problem. It's a textfont-problem. In Romansd the mm² are not defined. It's not working in ADT2004 too!!!
@ACLt 2000-users: Try textfont Arial. Don't forget "_regen"
Hope it helps,
Lothar
The fonts I use are Chemistry Serif and ChemistrySansSerif by J. Eric Slone.
They can be downloaded for free at http://www.scs-intl.com/frameload.htm?/chemfont.htm
They also include upper and lower case greek as well as some other scientific symbols.
