Can you look up graphs?
I have created a graph (XY scatter with data points connected by smooth lines) by putting in information that i need. No trend line seems to fit it at all. It would be very helpful if i could obtain all the y-values for every 0.01 incriment of x. Is there a way i could do this?
Many thanks...
RE: Can you look up graphs?
Can you divide the graph into sections and get a trend line for each section?  If not, perhaps you have a discontiunity which you should investigate.  Assume that you have tried expotential, log, etc. functions other than a polynominal.
I think the original poster wants to do a straight line interpolation betweeen each pair of data points at a regular interval.
Sounds easy.
Just write the equation for the straight line joining each pair, and take it from there.
Cheers
Greg Locock
Thanks guys, all very helpful!
Espically yours jerod as it lead me to what i had been looking for.
Ben.
