Can't load profile in MDT6
I recently installed MDT6 on a laptop running Windows XP Home edition. At startup I get an info dialog informing me that a bad profile was specified in the command line (c:\program files\autodesk\MDT6\acadm\mdtpp.arg)
then it defaults to the unamed profile. I have trid to manually load profiles through options without success.
I have even tried installing MDT 2004 and have the same problem.
Any help would be greatly appreciated.
