Pivot Table
Pivot Table
I Have just encounted an unuasual problem with pivot tables and just can't seem to sort it out.
I have a list of valves and fittings, and the quantity (serval of the same type with in list). I am using the pivot table to quickly and easily find the total for each type of valve and fittings etc -seems easy enough.
The problem is when I do a sum Qty, I get 1 item less than I know I should have for only 1 item, the rest are fine. I have checked this by doing an auto filter on the items and summing the quantites from there.
Has anyone else encounted this sort of problem, where the pivot table doesn't oick up all items, and if so how does one fix this.
Many thanks
Many thanks
RE: Pivot Table
Best regards
Morten
RE: Pivot Table
I Have double checked that the entries in the cells in which the pivot table uses are correct, and there is no unwanted gaps or anything.
This seems weird.
RE: Pivot Table
Cheers,
Joerd
RE: Pivot Table
This is why I say the problem is unusuall
RE: Pivot Table
Good luck!
Cheers,
Joerd
