Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have answered some questions and have gotten answers for my questions. Anywhere you can do this on one page helps tremendously..."
Geography
efighettib (Structural)
22 Jan 04 11:58
Hello
Someone knows any command that keep the program waiting for a few miliseconds, without using the timer control?
I need this to put between two calls
Call function1(a,b,c)
***** Here is the wait ****
Call function2(a,b,c)
Thanks a lot
Helpful Member!  efighettib (Structural)
23 Jan 04 9:37
After a long wait, I solved this problem on my own.
In a module, you have to declare
Public Declare Function GetTickCount Lib "kernel32" () As Long
Public Sub wait(ByVal dblMilliseconds As Double)
    Dim dblStart As Double
    Dim dblEnd As Double
    Dim dblTickCount As Double
    dblTickCount = GetTickCount()
    dblStart = GetTickCount()
    dblEnd = GetTickCount + dblMilliseconds
    Do
    DoEvents
    Loop Until dblTickCount > dblEnd Or dblTickCount < dblStart
End Sub
all what you kave to do now is to call wait(num), when num in the amount of miliseconds that the program waits to continue in the next line.
I hope this help to the rest of you.
meintsi (Mechanical)
23 Jan 04 16:57
This is easier:
Declare Sub Sleep Lib "kernel32" (ByVal milliseconds As Long)
' pause for 5 seconds
Sleep 5000
Remember...
       "If you don't use your head,
                       your going to have to use your feet."
CajunCenturion (Computer)
25 Jan 04 2:46
One thing to note about the Sleep command, is that it suspends all processing for that process while it's sleeping.
So if you want to wait for a few seconds, and not have the program do anything during that time, then Sleep is fine.
On the other hand, if your time delay is allow some other routine in your program sufficient time to complete its task, then Sleep will not work, because the other routine that you're waiting on, will also be sleeping.
Close Box
Join Eng-Tips® Today!
Join Us             Close
