Weld all around
Weld all around
Weld all around
I am working in Unigraphics NX, trying to add weld symbols to a drawing.  I think I have it all figured out, except I can not figure out how to add the all around symbol.  There is an option to put the field weld symbol, but not the all around, which goes in the same place.  Can anybody help?
RE: Weld all around
Its in the "leader" window/menu.  After you setup your weld symbol (type of weld, side, etc.), click ok, and then change the leader type, to the one with the "all around" symbol.
-Dave
http://www.moslerauto.com
