Density measurement
Density measurement
Density measurement
I've got a cone which is 4m top diamter and 0.3m bottom diamter. The cone is used in a Dense Medium circuits. it operates with FESI as a medium.
I am looking for a density measuring sytem, that can measure density from inside the cone. i've tried a pressure differintial sytem and it blocked within two days due to the medium.
RE: Density measurement
try www.solartronmobrey.com. You might be able to use their long extenmsion insertion density transducers (zone O approved under ATEX, i believe)Do a search under vibartional or digital denisty meters for more manufacturers.
