Intralink file overwrite, help required
I checked out an assembly into the wrong workspace this morning, overwriting 3 days of work (un-checked in).
Is there any way to revert a workspace to the condition it was in the previous day?
I can see all the files I need in the .proi directory, just can't get at them through intralink.
Thhanks in advance
Thhanks in advance
RE: Intralink file overwrite, help required
Highest regards,
NbLYLYDdy
It would be a great help if PTC left the checkout workspace blank, that exactly why I made the mistake. I am going to recomend to our design team to have a workspace called 0000 or somthing similar to help catch these errors.
Have you tried "importing from disk" under the"object" menu and working up through the directory structure?
Joe Borg
www.methode-eur.com
Go into MyComputer and into the back door of file management.
You can fine the Intralink WorkSpace, list files, and remove files or copy files just like any other computer file. Just remember to copy files with higher numbers if you want it to be the one checked into Intralink.
I do not know if I understood you or not. NEVER remove or delete files via explorer or any other file manager in the operating system below the workspaces directory. This will
corrupt your "local.ddb" file wich keeps track of all files.
Joe Borg
www.methode-eur.com
It is a work around ... not a normal work flow! Don't do this often and I don't keep workspaces long.
