Working with realview
When I set the material in a part to Aluminum, A6061, it looks like the part is either Stainless Steel or chrome. Am I missing something but what I was looking for was something more realistic which would be a dull finish. Is this what everyone is seeing or is it just me?
I am opn SW2004, SP1 and my graphics card is a Nvidia Quadro4 900XGL
Thanks in advance
RE: Working with realview
I get the same, but is OK.
If you want a dull finish, change the texture to what is good for you.
Again, I might be missing something but if I add a texture like Metal, Brush metal 1, you can't see or use realview if you have a texture applied. I can click realview on or off and nothing will change once a texture is applied
Check your video card. Some cards will not support realview
That card does support Realview...
I'll see what I get when I try...
Nick
I love materials science!
Certain drivers are needed for Real view to work. Make sure you have the Shader file folders install on your system. if not then you can do a modify and re-add them.
Try making a new part and see if it works for that one.
I had a part that would not work properly. I would have to RMB the material and go in to the command then click cancel. After I did that and added a texture then Real view would work. The problem was in the file and not with SW. So try it with many different parts.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
