Creating an NC program from a DXF or similar
Hey All
Im looking a piece of software will out put a 'G and M' NC Code where the input it a dxf or similar (similar to ProCut seen on http://www.espritautomation.com/procut.asp)
I have a gas profiling cutting machine that cuts profiles on the ends of Fork Lift Truck Forks so the programs and profiles are very simple
i.e. cuts one at a time. No need for nesting etc
All the progs I have seen so far are very expensive
and have more features than for what I need
I hoping there is shareware/freeware/demo of a simpler option but any recommendations are appreciated
TIA
TIA
Milkboy
RE: Creating an NC program from a DXF or similar
I wonder if any of the cheaper sign cutting programs would make something like G-code.
Otherwise- do you suppose that HPGL could be massaged?
worth trying...
regards
jay
Jay Maechtlen
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
Or, ask around, your local community college engineering technology department should have several students that can write G and M code easily. You would be suprised at how easy the language really is. With only minimal exposure you could be writing simple programs in a day or two.
http://www.artofcnc.ca it is designed as an inexpensive step and direction controller, but will import DXF or HPGL and save the resultant G-Code, the trial version is good for up to about 1000 lines of code, registration is $150.00
erie
http://www.ribbonsoft.com/camexpert.html
You can download a time limited trial and the purchase price is reasonable. While you are there Qcad is also worth a look as a basic but usable cross platform 2D CAD package.
