Pipe & pipe fittings standard code?
Hi all,
I'm really a PC programmer with a ... hard task?
A small company that distributes pipe and fittings for the oil industry hired me to develop a program that will handle their quotations, invoice, etc.
My question is this: Is there a standard code that will allow me to identify an specific material, like for example
"Casing 6-5/8" J-55 24PPF BTC R2 API 5CT"
I´m completely lost in this, so any hint will be highly appreciated,
Thanks a lot in advanced,
Mario Osorio
Mario Osorio
RE: Pipe & pipe fittings standard code?
"Plagiarism is the greatest form of flattery!" Take a look at how a large pipe and fitting distributor handles its stuff. Create yourself a user id at http://www.mcjunkin.com and see how they code their products.
jt
I have almost same problem. I may ask you that if you can share your experience on the way to reach a coding methodology of equipments/materials. What is your status. I have a coding teqnique for downhole pumps which I found from an API code (spec 11 AX). But still I need an unique coding system for all kind of material and purpose.
Thanks in advance,
hguzel
