cold formed steel
cold formed steel
Can anyone recommend a good computer programs for the design of cold formed steel structures and masonry structures?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: cold formed steel
http://www.steel.org/construction/design/index.html
You can also download a program from www.clarksteel.com
The program is called AISIWIN. DEVCO software also has several programs available.
The NCMA has several programs available for masonry design. I have evaluated several programs over the years and found, Unfortunately, most masonry design programs are not very good. Most of the programs are rather cumbersome.
Most engineers don't "design" masonry, they use what has worked for them in the past.
I design masonry using the ASD method. I find that I can design a reinforced masonry wall quicker by hand than with a some of the programs I have evaluated.
Regarding the j/k method, there are chrts and tables available with the various j and k coefficients calculated. I agree if you need to calculate the j and k everytime using the equations it is a nightmare but the tables are quick, and easy.
