COSMOS contact analysis
Does anyone know that how contact analysis can be performed in COSMOS for two surfaces of two bodies that are NOT in contact initially but they may contact later as a result of body deformation?
RE: COSMOS contact analysis
You need to define a surface type contact pair.  I recommend going through the tutorials available in DesignSTAR regarding contact problems.  That should help you out in learning how to properly define contacts in DS.
Thank you Joe for your help.
Shaun
