Shock load from high voltage short circuiting
I don't know if this is the correct forum, but I need to know what kind of mechanical loading (I would assume shock load) is produced when a 22kV circuit is shorted. Experience from real life says that a wall some distance away (approx 0.5 m) is destroyed (part of the wall blown away).
Can anyone point me to where I can find information??
Thanks a lot!
Thanks a lot!
RE: Shock load from high voltage short circuiting
Forum and I assure you that you will get a lot of answers.
