Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...this web site is a 'Godsend' for me. If I have a programming problem that I'm unable to solve, I'll get a sensible reply in no time. It's really great!..."
Geography
waterguy (Civil/Environmental)
3 Jul 01 11:36
I have a columm of data and need to calculate the sum of every seven (7) values.  For Example, the sum of values 1 thru 7 (inclusive), then the sum of values 2 thru 8, then 3 thru 9, etc....
This is simple enough, but the problem is that the data is incomplete, and prior to summing the values I want to perform a check to ensure that there are no empty cells (ie. no data) within the set of numbers that I want to sum.  If a cell(s) are empty I will indicate that the data is incomplete and not perform the sum for that set, otherwise, I will perform the sum.
Is it possible to check values in a Range using an IF statement ?  Or to check for for an empty cell within a range using an IF statement ?
I have used VBA code in the past, and was anticipating doing it for this, but I thought I would pose the question to see what others thought, or if there is an easier way to do it.
Thanks.
linqur (Mechanical)
3 Jul 01 12:36
Hi watergui,
Paste this in A1 =IF(ISBLANK(B1);"Empty";"Something")
and change values in B1.
Hope it helps
Linqur
3 Jul 01 13:58
Thanks for the response Linqur.
I did some more digging and figured out a way to do it using a COUNTBLANK statement nested inside an IF.  See below:
=IF((COUNTBLANK(A1:A7)>0),"INCOMPLETE",(SUM(A1:A7)))
It seems that half the battle with Excel is getting to know all the functions that are available !
linqur (Mechanical)
3 Jul 01 14:22
Yes right
you wanted to check 7 cells for incompletes.
Help system is quite useful once you've
spent enough time reading it and have gathered
bookmarks in you mind "I saw once something about that somewhere".
Linqur
Close Box
Join Eng-Tips® Today!
Join Us             Close
