Annotation note in the model tree
Does anyone know if you can insert a note into the model tree? If so, how do you do it? I'm using Wildfire by the way.
Thanks in advance
Jeff
Thanks in advance
Jeff
RE: Annotation note in the model tree
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Yep, that is what I do. I just use a 'Default coordinate system'. I think this has a very low regen time (does not impact regen performance) and it does not need any parent relationship.
im4cad
Michael
I'm not sure if you made it Read Only feature would hide the modify action from the Pop-up menu. You might want to try that to protect the Model or Feature notes.
This way you can view the note without having to put it on a layer although the Using Layers for the notes might be better and easier to view the notes depending on your approach.
Michael
