Spaceball Not Rotating In Sketcher Mode - V5R11 SP2
Hi
The spaceball rotates in any other mode apart from when switched to Sketcher mode. In this mode it only zooms in and out or moves around the screen but does not rotate.
any ideas - anyone.
any ideas - anyone.
RE: Spaceball Not Rotating In Sketcher Mode - V5R11 SP2
Tools + Options + Display
In the Navigation tab, turn off the Gravitational Effects
IF YOU ACTIVATE THE 3DX DEVICE TOOLBAR YOU CAN THEN "CLEAR" THE "ROTATE ICON"
I've contacted 3D connexions and they are aware of it.
It is on Dassaults plate to fix since they caused the problem with a change that they made.
Hopefully this will be resolved in the next service pack of R12.
Currently I'm on V5R12 Service pack 3 and the issue still exists.
Thanks for all your input - I too believe it is a known problem. Have tried it on V5R12 Service Pack 4 - it works a treat.
Therefore there must be a fix that sorts this problem out. I will investigate and post the results here.
APAR NUMBER: HD16211 RESOLVED AS: (still open)
ABSTRACT:
HD16211: NO ROTATE IN SKETCHER WITH 3D MOTION CONTROL DEVICE
ORIGINATING DETAILS:
No rotate in Sketcher with 3D Motion control device
Scenario:
When in sketcher can not rotate off sketch plane
with a Spaceball 4000FLX or a Magellan XT. The
latest drivers for the device are installed. This
works in R10. Rotation with the mouse is ok.
LOCAL FIX AS REPORTED BY ORIGINATOR:
RESPONDER SUMMARY:
(This APAR does not yet have a Responder Section)
RESPONDER CONCLUSION:
TEMPORARY FIX:
COMMENTS:
APAR INFORMATION:
Reported to correct a PTF in error: NO
Reported as a highly pervasive problem: NO
Reported as a duplicate problem: NO
PE Apar?: NoPE
HIPER Apar?: NoHIPER
DUP Apar?: NoDUP
Status: OPEN
Component Name: CATIA V5/NT/200
Version: 511
Component ID: 569151000
Submitted: 04/01/14
Closed:
Last Modified: 04/01/20
Change Team: FR3751
This will enable the rotating in sketch for CATIA.
Best Regards
Lars
If u wanna use the spaceball for rotation in the sketcher mode press button 3 (space ball handle) and hopefully it should work.
