Submersible Motor Winding Wire Supplier
I require to purchase Winding Wire suitable for rewinding  large HP water filled submersible motors operating at70 -85 degress ,415-460 volts  50-60 hz 2 and 4 pole .Not PVC type insulation.Prefer PP PA or PE PE
Can any one advise suppliers of suitable product.
Regards Grover194
RE: Submersible Motor Winding Wire Supplier
Can't help you with wire but I think you mean oil-filled motors and NOT water filled. Is this right?
buzzp,
no definetly water filled  submersible motor, eg Pleuger, Mercury, Emu ,Hitachi , These can also be up to 1000 and 3600 volts .
Grover
Interesting, never knew something like that was around. Will have to check out some mfg's web pages. Thanks
grover194.
 if you contact the local pleuger/mercury agent(distributor) and ask for a complete winding repair kit .
in this kit you get winding wire slot insulation,phase insulation ,connection kit and banding tape.
kind regds
Thanks Teco,
been there--done that,
Not applicable
HELP needed
Grover
I forgot to mention, Essex works with Franklin Electric, a mfg. of submersible motors.
grover194 just recived this web site from one of our suppliers www.omerin.com give it a go good luck.
kind regds
gcaudill, Thank you,
I am already supplied by Essex for other wdg wire ,they cannot assist with Double Jacketed Wire suitable for water filled operation.
Franklin motors are encapulated,this uses an enamalled wire and then epoxy filled.
I am seeking a European supplier.
I'm mainly familiar with submersible pumping equipment used for oil production. We used Kapton insulated copper windings for class H rated systems. In the US, try Zeus.  In Europe, the only one I'm familiar with is Dedal in Moscow.
Thank you Dale 549,
I am familular with Kapton wrapped wire for oil filled subm motors.
I still have no leads for water filled motors. I was told a manufacturer in Germany . Name like " NSW " or this may be an abreviation.
Any help appreciated.
Grover
Answer.
Finally tracked down a supplier in Germany .
  www.nsw.com
PO box 14 64
D-26944 Nordenham
Germany   +49 4731 82 0
Grover
