Partial surface of Bodies
Hi all,
I´ve trying to measure the volume of a Body in a Catpart. So far no problem: I´ve found the right function.
But I´d also like to "partially" measure its surface. That is, the Body is faceted, and I´d like to measure the total surface of only two of its faces, not all of them.
Well, any ideas (cause I haven´t got any :o(
Thanks in advance!
Thanks in advance!
RE: Partial surface of Bodies
In the Part design workbench, the only surface functions I found measured the total surface of the part.
BUT, if you create a Catproduct and insert the part in it, you can now use the Assembly Measure functions on the part!
I just have to measure separately the two faces, and then create a parameter: TotalSurface= Surface1+ Surface2.
Easy, isn´t it ?
No need to go to catproduct. In part design itself in measure item tool, check the keep measure icon so that u can continuously measure areas of surfaces.
