What does SIP stand for ?
Hi Guy's,
I use to work in the food sector and I know
CIP : cleaning in place
but what does SIP mean
Sterilisation in place ?
I'm also looking for some information according
centrifuges for the pharmaceutical industry, do you
people now some good website's.
Thanks in advance Rudi
RE: What does SIP stand for ?
Regards.
(Sterilise in Place here in the UK)
Try
www.ellerwerk.com for centrifuges
First thank you for the replies,
Mizkn,
Can you explain Steam in place a little bit further, it seems other people also call it sterilize in place. Or do you think we're talking about the same?
Arnie04,
Thanks for the link this was what i was looking for.
cheers
Related...yes, sterilization in place covers it...
Steam sterilization vs a cleaning agent sterilization..it depends on your process needs/design. If you are still looking for more centrifuge info try posting on the Pharmaceutical engineering forum under Chemical engineering. Your food industry CIP experience will assist.
Regards.
A typical sterilize in place cycle is 30 minutes when pure steam temperature is 1210C and with 1350C it can be as low as 10 minutes.
Further, when a critical equipment cannot be exposed to acids, alkalis and detergents, the CIP is done with steam and the term Steam In Place is used alternatively.
Check the website of WestFalia at
http://www.westfalia-separator.com/en/index.htm
