How to hide sketches in a large assembly?
Hi all!
We have a hard trouble.
We switched from CATIA 5.7 to CATIA 5.10.
As we loaded our job in 5.01, which is a large assembly (>2000 catpart and 50 sub-assemblies) every part has in show all sketches.
We see that the only way is to get into every catpart and use the feature under "instruments" -> "hide" -> "sketches".
We are trying to use a macro, but, when saving the macro, it doesn't save this operation.
Is there a more smart way to work on it?
Please, we need it badly...
Thanx in advance,
Sergio.
RE: How to hide sketches in a large assembly?
You don't need a macro to do this just call u your top level product.
use the search function under the edit pull down.
Search in the Part Design workbench for sketch.
Use the select button.
Under the Tools pull down select hide then select selected elements.
Now just do a save management on your top level product.
Hi Puck,if we do like u said,itz making the whole product hide,we just have to hide only the sketch,I think macro shud work in this case,
bye
Naveen
Once you have your main product up just get into one of the parts so the part design work bench is active then it won't hide everything.
Sorry guys I was crossing this post up with the one to select the sketches.
Yes when it comes to planes noshowing the selection will also noshow the geometry.
When writing the script approach it this way.
You need to get the top product and it's collection.
Then loop through it's collection and qualify  if it is a product or part.(Check the name to see if it has CATPart in it.)
If it returns a product you will need to drill down through it also.
Once you have a part you'll make it active and then noshow the planes.
Since Dassault hasn't given us any save managment tools in script you will have to save each part and it's parent product or nothing will be saved.
HTH,
puck
hi,
try knowledgeware...expert rule.
very quick to set up  and use...
Eric N.
catiav5@softhome.net
