cut the model
cut the model
Can I cut a solid model with surface in ProeWildfire?
I do it in ProE2001.
Thanks.
Thanks.
RE: cut the model
If it doesn't work, intersect surface & solid by creating a curve. Visually, search for openings. Sometimes, this curve is needed in model tree because of math generation requirement to do complicated features. It seems to know curve is through same area and work expediently.
RE: cut the model
Good,thanks!
