UNION not giving expected result
I need to create a .csv file grouped by Account, Ccentre with 14 columns, OBAL, JAN, FEB, etc to CBAL.
I have existing views to get the data into the individual parts, the following is for JAN:
SELECT     SUBSTRING(GL06001, 1, 4) AS Account, SUBSTRING(GL06001, 5, 4) AS Ccentre, GL06004 AS JAN
FROM         dbo.GL060102
WHERE     (GL06014 >= CONVERT(DATETIME, '2002-01-01 00:00:00', 102)) AND (GL06014 <= CONVERT(DATETIME, '2002-01-31 00:00:00', 102))
this will give a table of entries for JAN only.
I have tried the following to ADD the views together to give a result with OBAL, JAN as columns but only get OBAL
CREATE VIEW dbo.[24HR_GL06_2002_groupby]
AS
SELECT     Account, Ccentre, OBAL
FROM         dbo.[24HR_GL06_2002_OB]
union
SELECT     Account, Ccentre, JAN
FROM         dbo.[24HR_GL06_2002_JAN]
How can I get all 14 periods?
RE: UNION not giving expected result
The UNION command appends the new data as rows, not columns.  So based on the SQL you have, you should get one row for OBAL, the next for JAN, then FEB, etc.
Assuming that each unique combination of Account, Ccentre has only one record in each table, then you could do something like this:
SELECT OB.Account, OB.Ccentre, OB.OBAL, JAN, FEB, ..., DEC
FROM dbo.OB OB, dbo.JAN, dbo.FEB, ..., dbo.DEC
WHERE dbo.OB.Account = dbo.JAN.Account
  AND dbo.OB.Account = dbo.FEB.Account
  AND dbo.OB.Ccentre = dbo.DEC.Ccentre
ORDER BY OB.Account, OB.Ccentre
But this will probably be a very big, time-consuming query since it has to go across 13 tables and make 26 cross-table comparisons.
Hope this helps!
