Supply Air Temperature Control
Concerning a big theater Hall where I have to install the sensors to control the supply air temperature ?
RE: Supply Air Temperature Control
How about a better description of your problem?
Other answer is to put RA sensor beside the seat where you sit most ...!!!
I think PaulKeating has a point about stratification, particularly, as you said this is a theater. How about multiple sensors in the controlled space and averaging them?
Is this what your really want to do?
more sensors shall installed inside the threater (low level perfer) to measure the indoor temp. of the threater and than averaging them. It is more accurate than simply place the sensor near the return air louvers.
