Remove CO2 from effluent gas
Hallo
How can i remove CO2 completely from an effluent gas from compressor at rate of 5m³/min.Thanking you in advance.
Fahims
Fahims
RE: Remove CO2 from effluent gas
Pretty hard to answer without some details.
We used a caustic wash to remove the CO2 out of our cracked gas before the chilling train but if you have substantial amounts of CO2, that can get expensive in terms of caustic consumption.
If this is a lab system, you can get a CO2 scrubber filter from your local lab equipment vendor. Be sure to let them know as much as you can about your effluent gas so you don't get surprises.
Thank you all for your suggestions.Will be using some specially treated caustic soda.
AND SOLVENT FOR THIS WORK IS DEA
