Buckling in Curve Plate
What would be the appropriate model for the buckling of a curved plate? I'm looking to understand buckling in thin films (0.005" thick polyester) when it is in a curved shape, like a half cylinder. This for printing press style handling systems, where the product is wrapped around a rolling cylinder, but in some cases the cylinder would be undercut to prevent contact in the middle, like a sprocketed roller in an old film projector, but on a bigger and wider scale.
RE: Buckling in Curve Plate
Steve Braune
Tank Industry Consultants
www.tankindustry.com
The moving web is controlled to run at a given speed, but also a machine direction tension, typically 1 lbf per in of width. This tension pulled over the cylindrical roller creates a pressure on the cylinder of Tension/Width/Radius (psi).
In some cases, to it is desirable not to contact the center of the web (it is contact sensitive to scratching or contamination). In these cases, an undercut roller, a cylinder with small diameter in the center, is used, so the curved, tensioned film is only supported at the two ends. The problem is understanding what conditions this is unstable, where the cylinder created by the polyester film will buckle rather that hold its cylindrical shape. Radius, unsupported width, tension, modulus, thickness, supported width, all seem to be factors.
This doesn't fit Euler's buckling criteria, since it is not axially loaded. Also, the slenderness ratio (L/r) places most cases in the "short column" catagory. Lastly, an axial loading model will show larger diameters support more load, where I know from practice, that small diameters are stiffer for this scenario.
Does this give you a better picture?
Steve Braune
Buckling of curved plates has on occasion been termed buckling of the barrel vaulted roof. A google search on this term will produce many hits. However, your thin film has no bending stiffness, and if wrinkling is involved, you will probably need to use finite element analysis to solve the problem.
cab
Steve Braune
A formula in the Roark gives the critical radial pressure over a curved thin panel with straight edges simply supported. The panel should be very long (take l>10r), so that end supporting conditions are non influent.
It is:
Et3(π2/α2-1)
p= -------------
12r3(1-ν2)
where:
E=elastic modulus
t=thickness
α=half opening angle (=π/2 for a half cylinder)
r=radius
ν=Poisson's ratio (=0.5 for elastomers)
The condition of support at straight edges is quite close to yours, as the straight portions of the film coming out of the curved part act somehow as supports (they allow only for sideways displacements).
Note also that, as one would expect, that formula reduces to that of a full long cylinder for α=π/2 (due to symmetry a full cylinder behaves as two facing half cylinders).
Now it is necessary to transform the uniform radial pressure of the formula into the film tension of your setup. This is simply done by calculating the edge reactions of the curved panel in the direction normal to the tangent.
This is simply
T=pr(1-cosα)
By combining both equations you should get a quite good estimate of what you are looking for. Of course you will also need to take a margin of safety with respect to the critical value: a factor of 3 is normal in metal construction, but a value of 5 could be more appropriate for you.
prex
http://www.xcalcs.com
Online tools for structural design
tjw
A few questions, if you don't mind, because I'd like to picture a few more details.
What percentage of the sheet is supported vs. unsupported middle?
Is there a sharp edge transition to the undercut middle part of the rollers?
Do you control friction with lubricants?
Is the roller perfectly cylindrical?
Is the buckling provoked by misalignment of the rollers?
Is the film at room temperature?
Is the film homogeneous? (ie., is this one sheet of the same material, or laminates of several?
Again, excuse the interrogation, but you have piqued my interest.
"Simplicate, and add more lightness" - Bill Stout
Steven Fahey, CET
What percentage of the sheet is supported vs. unsupported middle? (This would usually be a low percent, say 0.25-1" on either side of a 8-14" wide web, but I'm wondering what the limits are...one of the reasons to find a model for this.)
Is there a sharp edge transition to the undercut middle part of the rollers? (Likely yes, but the transition edge would be tapered or rounded. I've been thinking to myself how this aspect of the design increases the shear stress at the transition and may greatly change the design limits.)
(No, this is usually a dry friction, steel-polyester, aluminum-paper, and such. Rollers are usually metal, or rubber covered metal cylinders.)
(Traditionally, yes. However, some subtle tapers are used in special applicationns, usually less than 1-3 mils per foot taper.)
(This can promote and create shear related buckling and is well model by work from the Okla. St. U Web Handling Research Center. I'd like to ignore that here.)
(It can be, for drying solution coatings, but usually room temp.)
(Mostly homogenous papers or films, sometime with a thin coating, at least what I'm concerned about.)
Think on.
tjw
Have you tried tapered rollers? I'm thinking that a taper that slopes away on each side of the 12" gap would tend to stretch the film across the gap slightly. If the edges contacting the roller aren't critical it may not matter how you blend from the major OD to the minor one. The tapering may make the sheet want to travel side to side, perhaps far enough to slip off one support. You'll need a keeper of some sort. Hmm, as soon as it touches a keeper it might just start wrinkling up again... Vibration (depending on the speed of the system) will get the sheet spanning from roller "A" to roller "B" wobbling about, which complicates your analysis, if you want to take it that far.
A rough attempt at illustration:
keeper taper groove taper keeper
|___/| |\___|
Okay, your shaft is pretty complicated now. This is the typical effect of my ideas.
Steven Fahey, CET
What I'm interested in now is moving beyond this limitation to intentionally moving the center to zero and totally unsupported. Yes, a challenge it is.
I appreciate your insight. I'm curious how a thin shell engineer understands the "spreading" effect, since it is a novel interaction of a moving web over non-cylindrical rollers. Have you worked in the converting field before, or is this trick well-known enough in design of belts and pulleys? tjw
Are you saying you want zero tension across the sheet (along the roller axis)? Uh-oh - you'll be relying on the stiffness of the substrate, for sure.
Is the delicate coating on both sides of the film, or just one? Can you pass the sheet through double-rollers? (Where the idler is a full cylinder)
O)O The idler is on the outside of the turn.
As for analysis of thin shells, Prex already got you going on the right track, IMO. Do you have a copy of Roark's Formulas for Stress and Strain? Beware the end-restraint assumptions in any analysis you do, because the edges of your sheet aren't simply-supported by the roller, nor are they fixed, either.
Steven Fahey, CET
Thanks for your input. I've ordered a Roark's (didn't have one, but should of).
As to your Qs:
1. Product can be coated on either side, but one-sided is the concern here.
2. Yes, you can do this, but the difficult goal is turning the web contact-sensitive side in, which you may need to do occasionally.
Thanks for the warnings on end constraints. I want to get a model to get started, but expect some experiments will be the "proof in the pudding".
tjw
