spindle taper angle
spindle taper angle
I am designing a tapered spindle and I don't know what angle, length, etc. to use.
20 000 rpm
20 lb side load
1 lb end load
approximately 2 inch maximum tool lenght
will operate 10 minute intervals, 2 times per hour, 10 hours per day
want to use nut to hold tool in place and remove by hand - do not want to use a drift or draw bar to remove tool
Any guidance from tool designers?
20 000 rpm
20 lb side load
1 lb end load
RE: spindle taper angle
