ADDING COOLING POWER TO A EXISTENT SYSTEM
Hi all.
I had 3 (8,5 and 4 floor) buildings with water chiller ,used for VAC 8 °C leaving water 13 °C return.
First a 100 TR on a roof of the 8 floor building to supply to the lowers floor.
A 40 Tr and 20 TR in parallel at the roof of the 4 floor building.
And one 200 TR on the 5 floor roof to help the other two and for futre use and ampliation on the 3 biuldg.
QUESTION.
In wich way should I do the interconection so it can became a whole system?
The 100TR and 40+20TR have its pump , manifolds , etc.
After the system is runing, a control system to run and start each chiller acording the demand.
The system is for a Hospital , so some parts of it need cooling all year round.
Thanks in advance.
QUESTION.
Thanks in advance.
Pardal
