Copy Excel column in VB6
I'm writing a Visual Basic program that accesses existing Excell files.  I need to select an entire column and then insert the entire column, shifting all columns to the right.  Excell's macro recorder shows:
Worksheets(1).Columns("C:C").Select
Worksheets(1).Selection.Copy
Worksheets(1).Selection.Insert Shift:=xlToRight
But, VB6 only likes the first line.  This must be a simple question, I hope someone knows the answer!!
Thanks!!
