Cretaing text features
Can anyone tell me the easiest way to create text in an arc fashion?  I need text to go around the edge of a cap.
Thanks for any help provided.
RE: Cretaing text features
There is a GRIP program in the griplib called o_text.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
At the risk of sounding like an amateur.  What and where is the griplib/program usually located in NX?
Thank you
<loadpoint>GRIPLIB in my case c:\ugs180\GRIPLIB
The library is distributed in a .tar format. You will need to expand it to find the o_text.grs file.
Ben Loosli
Ingersoll-Rand
There is also a tool written by Weideman Engineering
(www.e-eng.de) in Germany, called True Type 2 UG. It gives a very nice graphical interface to create splines from any True Type font on your system. It works VERY well, but keep in mind you must have a UG API Execute license to run it.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
Sorry... That web site is www.w-eng.de
-Derek
