Spanner Drawings
Spanner Drawings
An assembly I'm currently designing is exceptionally tight for space. I want to see how much access I have with a standard 8mm spanner (closed one end, open the other). Anyone know where I can find a drawing showing typical spanner dimensions that I can model for insertion into my 3D model. Have googled without success.
RE: Spanner Drawings
Be careful as these wrenchs come in different weights depending on use.
DIN 3113 / ISO 3318 •• ISO 7738
http://buy1.snapon.com/catalog/catalog.asp
It will probably take you longer to find, download & possibly fix the model than to draw the spanner you intend to use.
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
http://www.iso.ch/iso/en/stdsdevelopment/tc/tclist/Tech...
Cory
http://buy1.snapon.com/catalog/pro_det.asp?tool=all&ite...
