Pro-E for ANSYS FEA
Pro-E for ANSYS FEA
Pro-E for ANSYS FEA
Hi there all,
I have posted this same subject for Solid Works thread. I need to know from the experienced guys out there if Pro-E most likely is the most common solid meodeling software used on ANSYS FEA? Thanks for everyones help.
Gimini21
RE: Pro-E for ANSYS FEA
Gimini
    It doesn't makes much difference, whether you are using Pro/E or Solidworks as a modelling software with ANSYS, if you are importing the geometry as IGES.
                                          Sarang
