Change in Spring Properties over 40 Fdegs
I have a relief valve (10psi,3/4 in, used for lube oil) that has been giving us problems. I am certain the problem is caused by the change in viscosity of the oil over the ranges of 60-100 deg F. However, a number of people I work with believe the spring(steel)stiffness is changing. I am sure the change is negligible; however, I have not been able to quantify it. None of my reference books give me any help.
Can anyone give me a rough value?
Thanks, Tod
Thanks, Tod
RE: Change in Spring Properties over 40 Fdegs
I also don't off hand think that the spring would be changing more than 1-4% in stiffness by modulus change w/ temp esp since your temps are so very low.
nick
Thread367-58751
ne
Steve Braune
Tank Industry Consultants
www.tankindustry.com
http://www.grantadesign.com/cgi-bin/stat-tree.cgi?src=M...
MIL-HDBK-5H available as individual chapters
http://assist.daps.dla.mil/quicksearch/
MIL-HDBK-5J (latest revision) - HUGE download!
Apart from Oil viscosity are you sure no vaporisation is occurring - especially if some water has got into the oil.
Martin
