Add-In Creation
Add-In Creation
I've create a macro in VB that createws a userform with shortcuts to all other macro's we are using in our company. This way I can add new macro's and update them without annoying the rest. I was wondering if I could create an add-in (for SW2004) that will create a standard SW-toolbar on wich I would be able to add/remove and update buttons. It would be very helpful if I have created a new macro I would be able to add it to the toolbar and then when everybody starts up his SW the next morning it would be on their toolbar as well. Is this any means possible ???
Kind regards, Bouke
Kind regards, Bouke
RE: Add-In Creation
Good Luck
RE: Add-In Creation
If you are going to make such a program, only use it for .dll's and compiled .exe's. Starting macros using the SldWorks::RunMacro call can cause the macros to behave erratically and produce unexpected results.
If you can't get through to BitWright, contact me via the email address in my profile. I have that template somewhere.
Also, I can send you the script for a similar program I made to add my compiled .exe's to the SW menu.
http://www.EsoxRepublic.com
RE: Add-In Creation
The program sounds interesting. Can you send me the script?
Cheers
RE: Add-In Creation
You can contact me via the email address in my profile. I don't post email addresses on forum, as it leads to much spam and gnashing of teeth.
RE: Add-In Creation
RE: Add-In Creation
RE: Add-In Creation
RE: Add-In Creation
Don’t give up. I have seen some amazing things done with Visual Basic 6 and SolidWorks that have saved companies $1000’s.
Bradley
RE: Add-In Creation
I was - and he did. So at least I didn't get coal.....
OK, OK, It's a reference to my holiday sig. "Be naughty - Save Santa a trip..."
