Column shrinking
Column shrinking
If I have a massive column of data, How do I form a new smaller column consisting of, say, every fourth cell?
i.e, If column A consists of cells containing the numbers 1,2,3,4,5,6,7,8,9
I want column B to be 1,5,9 by referencing A1,A5 and A9 in incremental steps.
RE: Column shrinking
=LEFT(A1,2)&MID(A1,9,2)&MID(A1,17,2)
will work for the given example, but will encounter problems if cell = 10,11,12,13,14,15,16,17,18 or any of the digits being bigger than 9.
You could always do TEXT TO COLUMNS, then create a CONCATINATING formula
e,g, If A1 = 1,2,3,4,5,6,7,8,9
then do TEXT TO COLUMNS, delimited, check COMMA, DESTINATION C1, then in AA1 enter this formula
=C1&","&G1&","&K1
Hope this helps.
maybe only a drafter
but the best user at this company!
If column A contains the data, Column B contains 1,2,3..., Column 3 contains "Mod{A1,4)", Column D contains "If(C1=0,A1," ")"
Select all the rows with your data and sort ascending by column B first and column C second. Do this sort in one action using the sort criteria provided by excel.
Every fourth cell in the original list had a number 1 in column B. Now all the 1's in column B will be grouped together along with the appropriate number that was beside it in columns A & C. Column C insures that all data are still in the same order as the original list.
B1: 1
B2: =B1+4
copy down 5 rows (last row should be 21)
C1: =INDEX($A$1:$A$21,B1,1)
copy down 5 rows
Our own solution uses a very similar solution to jghrist, but using OFFSET rather than INDEX. Unfortunately, like most solutions, this involves creating a "dummy" column to do the counting. Can anyone come up with some arithmatic within the OFFSET (or INDEX) function to avoid the use of dummy columns?
Thanks again.
Cheers,
Joerd
Spot on Joerd, Thanks!
B1: =INDEX($A$1:$A$21,(ROW(A1)-ROW(A$1))*4+1,1)
copy down 5 rows
The Data Analysis Sampling solution is easier, though.
