Plate heat exchanger
Please could someone comment on the max. tempareture difference allowed for a plate heat exchanger to cool water successfully? Please could you give me a tempareture range that one could go and utilize such and exchanger? Advantages/disadvantages of plate vs shell and tube and plate vs spiral.
Thanking you
Mech225
RE: Plate heat exchanger
Chemical Engineering , August 11, 1980 shows an article on plate HE that may answer all your queries. It is titled: Consider the plate heat exchanger by Raju and Chand. Suggest you try to find it in a technical library.
Better search for plate heat hexchanger manufacturer, they have software to calc , it are free to download and use.
 If you contact me I can send the link wher to get it
Pardal
pardal:
Alfa-Laval used to have an online PHE sizing software but it disappeared (for me at least) in the last "upgrade" of their web-site. Do you know a current link for Alfa-Laval PHE?
Better yet: Why not post those links you mention here?
Best regards
Morten
i dont think giving such information could be called "promoting". I dont know if you work for this company but even so...
Thanks for the info.
Best regards
Morten
ok
Pardal
